psychotic_satyr's avatar
Jan 15, 2017
r7000 can't connect to webinterface
I had my stuff all working, r7000 as an AP to my FIOS network, r7000 was the wireless point. everything was fine. I hit the auto connect button by mistake and it jacked everything up.
so i reset it, because i couldn't get it working again, started over, got connected, got the wizard, and am currently on wifi thru my r7000, connecting to my fios and browsing the web. I downloaded the genie software, and it can see my router and all that, but i can't for the life of me find the ip address of the router.
how do i determine what IP the router has on the local lan?
when i try to use routerlogin.net it tells me i have to be connected to my router wireless (I AM) but it's not letting me do anything. I really want to get access back to my readyshare device and i had it mapped via ip.
any help would be appreciated.
TIA
QM / PS
  • yes, checking the list of things in the fios interface I was able to find the r7000 and login to it so I could set it as I wanted. I am not sure how it got connected since it wasn't in the DHCP pool, but I found it like you said.
    Thank you for your assistance.
    QM
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi psychotic_satyr,
    If the R7000 is set to AP mode, you have the option to set static or dynamic. If it is on dynamic, check the FIOS router for the IP address of the R7000.
    • psychotic_satyr's avatar
      psychotic_satyr
      QM
  • JamesGL's avatar
    JamesGL
    Hi psychotic_satyr,
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
