klausn
Feb 08, 2017Tutor
Cacti app doesn't work
Hi all, It seems after updgrading some weeks ago to OS6.6.1 Cacti doesn't work any more.( I just checked it today) I removed the Cacti App, but now I can't find it anymore in the Apps to reinsta...
JennC
Feb 08, 2017NETGEAR Employee Retired
Hello klausn,
It is not listed in ReadyNAS apps. Do you remember who the author is? Did you get this from available apps of admin page? Please include the model number of your ReadyNAS.
klausn
Feb 09, 2017Tutor
Hi JennC,
First I'm surprized I get a reply on this from Netgear, but I'm really appreciated...... txs for so far.
To the point:
Yes, before the upgrade it was listed and available in the admin page "Cacti", because I used it and installed also.
Before it worked fine and when I checked again all the graphics are broken/empty or even away, well what happens over here!!!?????
I have this (ReadyNAS Ultra 4), it function really good I'm happy with it even I changed last year all the 4 harddisks (for better one performace and online duration)!
I also took in the past a risc to upgrade this NAS from OS4..... (the rest I forgot at this moment) to OS6 with success and no problems at all!!!!!
The risk I took was a the best decision I ever have made, because all went soother and faster.
Great but after the last update to OS6.6.1 there are only problems!
| Fri Jan 27 2017 8:58:00 | System: Antivirus scanner found a threat (Unix.Trojan.Mirai-5607459-1) in the file /bin/busybox. Please delete the infected file soon if automatic delete setting is not enabled. |
| Wed Jan 25 2017 9:47:52 | System: Antivirus scanner definition file update failed due to download failure. Check your Internet connection. |
| Sun Jan 22 2017 5:50:57 | Backup: Error backup job Full Backup: destination cannot be accessed. -->This happens sometimes! |
| Wed Jan 18 2017 14:34:59 | System: Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file --> I removed the file | |
| Wed Jan 18 2017 14:34:42 | System: Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file --> I removed the file | |
| Wed Jan 18 2017 9:36:55 | System: Antivirus scanner definition file update failed due to download failure. Check your Internet connection. |
The files I removed was acually not the problem, because I checked on this forum if there are more people with this issue! And Yes, I'm not the only one how has this problem! And I also know that Netgear is busy with it. Berhaps a new upgrade to OS6.6.2? But I don't know?
So it sounds strange behavior, but there are more problems with this OS 6.6.1.
Toppic: Just take a look the Antivirus problem too " Lots of Virus detection after 6.6.1 Update"
One more small issue / problem to add sinds OS6.6.1 is operational:
"I'm losing all my network-drives that I have added" (I get red crosses (8 times) from the mapped drives, This PC)
(Message An error occoured while reconnecting E: to \\READYNAs\media Microsfot Windowns Netwrok: The specified network name is no longer available)
I rebooted my PC may times but no luck!!!!!!!!
In the logging of the NAS is nothing to see about this issue, but I found out that rebooting the NAS is the only right solution.
After reboot the NAS, all network-drives are back alive! Strange way ...... right? (all this is happens after the last OS6.6.1 upgrade, before NO PROBLEM!
My question is: "Does my problem now include this OS6.6.1" version issue or not?
Can I reinstall it as before in the admin page?
Or do I need to download it and add it?
Please advise me?
Txs
