klausn
Feb 08, 2017Tutor
Cacti app doesn't work
Hi all, It seems after updgrading some weeks ago to OS6.6.1 Cacti doesn't work any more.( I just checked it today) I removed the Cacti App, but now I can't find it anymore in the Apps to reinsta...
klausn
Feb 09, 2017Tutor
Hi JennC,
First I'm surprized I get a reply on this from Netgear, but I'm really appreciated...... txs for so far.
To the point:
Yes, before the upgrade it was listed and available in the admin page "Cacti", because I used it and installed also.
Before it worked fine and when I checked again all the graphics are broken/empty or even away, well what happens over here!!!?????
I have this (ReadyNAS Ultra 4), it function really good I'm happy with it even I changed last year all the 4 harddisks (for better one performace and online duration)!
I also took in the past a risc to upgrade this NAS from OS4..... (the rest I forgot at this moment) to OS6 with success and no problems at all!!!!!
The risk I took was a the best decision I ever have made, because all went soother and faster.
Great but after the last update to OS6.6.1 there are only problems!
| Fri Jan 27 2017 8:58:00 | System: Antivirus scanner found a threat (Unix.Trojan.Mirai-5607459-1) in the file /bin/busybox. Please delete the infected file soon if automatic delete setting is not enabled. |
| Wed Jan 25 2017 9:47:52 | System: Antivirus scanner definition file update failed due to download failure. Check your Internet connection. |
| Sun Jan 22 2017 5:50:57 | Backup: Error backup job Full Backup: destination cannot be accessed. -->This happens sometimes! |
| Wed Jan 18 2017 14:34:59 | System: Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file --> I removed the file | |
| Wed Jan 18 2017 14:34:42 | System: Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file --> I removed the file | |
| Wed Jan 18 2017 9:36:55 | System: Antivirus scanner definition file update failed due to download failure. Check your Internet connection. |
The files I removed was acually not the problem, because I checked on this forum if there are more people with this issue! And Yes, I'm not the only one how has this problem! And I also know that Netgear is busy with it. Berhaps a new upgrade to OS6.6.2? But I don't know?
So it sounds strange behavior, but there are more problems with this OS 6.6.1.
Toppic: Just take a look the Antivirus problem too " Lots of Virus detection after 6.6.1 Update"
One more small issue / problem to add sinds OS6.6.1 is operational:
"I'm losing all my network-drives that I have added" (I get red crosses (8 times) from the mapped drives, This PC)
(Message An error occoured while reconnecting E: to \\READYNAs\media Microsfot Windowns Netwrok: The specified network name is no longer available)
I rebooted my PC may times but no luck!!!!!!!!
In the logging of the NAS is nothing to see about this issue, but I found out that rebooting the NAS is the only right solution.
After reboot the NAS, all network-drives are back alive! Strange way ...... right? (all this is happens after the last OS6.6.1 upgrade, before NO PROBLEM!
My question is: "Does my problem now include this OS6.6.1" version issue or not?
Can I reinstall it as before in the admin page?
Or do I need to download it and add it?
Please advise me?
Txs
klausn
Feb 09, 2017Tutor
Antivirus isn't automaticly updating, but after Rebooting he wil update once!
