b1jzcbx
Jul 10, 2023Tutor
can i restore a deleted volume? - PLEASE HELP!!
I'M IN A massive amount of trouble with this... i was adding drives and formatting them, and somehow all drives were selected, and it deleted the main volume. i have an rndp6000-200 updated to 6....
MikeD1234
Jul 11, 2023NETGEAR Expert
Hi b1jzcbx,
eden60 is correct, don't have the device powered on anymore, the more it's on, the more it'll overwrite data on the disk, where previous data was stored.
When you do a Factory Default, or, reset of the disks, it's clearing the metadata on the disk, but, doesn't fully zero-out the disks, this only happens on a full reset.
I would advise to contact a DR company, as they are maybe able to retrieve what was on the disk, with their hardware/software, as long as you didn't do a full wipe, but instead a quick factory default...
Hope this helps.
