LCL
Aug 30, 2011Aspirant
Can replicate make 1:1 clone?
I have two PRO 6 that I want to clone. Lets call them NAS1 (Primary NAS) NAS2 (Secondary NAS) They are connected on the same LAN, NAS1 is the one that all servers are connected to, NAS2 should o...
TeknoJnky
Aug 30, 2011Hero
not the way you desire.
The backup is a bit for bit backup of your data and config, but the backup device itself only stores the backup, it does not run or 'mirror' the source.
LCL wrote: What It looks like with Replicate is that I can make a full backup of NAS1 but if NAS1 explodes I need to replace it and then restore the backup from NAS2 to the new one... that will not work for me as it will take time to get a replacement if I dont just have a third PRO 6..
exactly, you must restore the replicated backup before you can use it.
