LCL
Aug 30, 2011Aspirant
Can replicate make 1:1 clone?
I have two PRO 6 that I want to clone. Lets call them NAS1 (Primary NAS) NAS2 (Secondary NAS) They are connected on the same LAN, NAS1 is the one that all servers are connected to, NAS2 should o...
TeknoJnky
Aug 30, 2011Hero
really it depends on the kind of data your storing and replicating.
assuming nas1 fails and you have to get up and working with nas2 asap, you could do something like this, provided you have sufficient space on the backup device:
simply copy (not move) the data from the replicate backup share to a share same name as source, then point your users/dns/ip to nas2
for example:
source nas1 (192.168.1.101) share = //nas1/documents
replicate destination nas2 (192.168.1.102) share = //nas2/replicate/nas1/documents
nas1 fails
on nas 2, create share //nas2/documents
create frontview backup job:
- source local folder /replicate/nas1/documents
- destination local folder /documents
depending on amount of data, it should go pretty quick since its simply a local file copy from one folder to another
once data is copied to nas2/documents then you can either change your dns/ip from nas1 to nas2 so that nas2 appears as nas1 to your users.
this is all very simplistic, and many factors could complicate it, like if running AD or using local users, or if your replicating iscsi luns, and I'm sure other things depending on data and how you use it.
for example:
nas1 fails
