Munber54
Jan 23, 2021Aspirant
can't access ReadyNas Pro 6 because it's still using SMBv1
Hi. I accidentally posted this in the wrong area and I tried to delete the post but I got a message saying it's too late to delet it...Anyway, my problem is that I have 2 ReadyNas Pro 6. but I can't ...
- Jan 24, 2021
RAIDar is just a program that runs on your PC to help you access the NAS. The OS for your NAS is called RAIDiator, and the last version is 4.2.31. That still uses SMB1, and there will be no further updates.
If you are running Windows, then you can (at least for now) turn on SMB1 under "Turn Windows features off and on". I'm not a Mac user, but I understand that's not an option in the most recent OS upgrades for them.
Your NAS can be converted to run the current ReadyNASOS, which is OS6 (6.9.6 is the long term support version and 6.10.3 the most current), and is what any new ReadyNAS you purchase will be running. It is not officially supported, and conversion will cause Netgear to deny you support, even paid. But many in this forum (myself included) have converted their NAS, so there is lots of help available here.
In addition to running a more up to date Linux core with SMB3 support and much more, there are many new features of OS6. Another big plus is that if your NAS does finally quit on you (it's getting pretty old, after all), you can just move the drives from a legacy NAS running OS6 to a new model that runs it.
But that means that if you want to convert your NAS, you are going to have to make sure you offload the data (to a backup you really should have, anyway) now and restopre after the conversion because OS6 requires a different file system and you cannot simply migrate the drives from OS4.2.x to 6.x.
It is recommended that you upgrade your RAM to at least 2GB, since that's what all Intel based native OS6 ReadyNAS have, so Netgear is not making sure it will run on the 1GB that's standard on a Pro6. Some have reported problems with only 1GB on more recent versions. It's also recommended you make sure your NAS is running the latest BIOS. It's not really necessary unless you plan to update the processor, but it's a lot easier to do under OS4.2.x.
If you do want to upgrade to OS6, see this: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-Pro-6-won-t-boot-after-failed-drive-addition/m-p/1855115#M184289 .
Sandshark
Jan 24, 2021Sensei
Munber54
Jan 24, 2021Aspirant
Thanks very much! That's a lot of helpful well organized information I can use. So as a first step, i better buy more hard drives to back up the files, which is kindof rough for me with my current financial situation...after that i will consider converting the NAS using your information...dissappointed that Netgear won't support the conversion...does not have me feeling good about the company
