scole
Mar 11, 2012Aspirant
Can't access Transmission web GUI
recently removed the old BitTorrent plugin and installed Transmission. All worked fine - could access web GUI with default username/password. Now: clicking on "Transmission Interface" Button on...
svendolph1
Jul 16, 2012Aspirant
HERBIEO wrote:
svendolph wrote: How to login in the webUI? I tape in user: admin and my password ore no password ore admin, nothing works
user: admin and password: password
edit: password is not your user password that you use for frontview log in, transmissions default password is password.
No luck with
(user: admin
password: password)
I have now removed the transmission, is there a way to bring back the BitTorrent add-on that was built into prior RAIDiator firmware?
