scole
Mar 11, 2012Aspirant
Can't access Transmission web GUI
recently removed the old BitTorrent plugin and installed Transmission. All worked fine - could access web GUI with default username/password. Now: clicking on "Transmission Interface" Button on...
mdgm-ntgr
Jul 16, 2012NETGEAR Employee Retired
It would be best to persist with trying to get Transmission working in my view.
The BitTorrent add-on is EOL and no longer supported. If you run into issues with it NetGear would only be able to help with removing the add-on.
However for now you can get it at http://www.readynas.com/download/addons/4.01/BitTorrent_1.3.bin and install via System > Update > Local if you have a Duo (v1) running RAIDiator 4.1.x. There is no BitTorrent add-on for the Duo v2, just Transmission.
An alternative (but not a very good one) would be to downgrade to firmware that included it and do an OS Re-install.
