scole
Mar 11, 2012Aspirant
Can't access Transmission web GUI
recently removed the old BitTorrent plugin and installed Transmission. All worked fine - could access web GUI with default username/password. Now: clicking on "Transmission Interface" Button on...
HERBIEO
Jul 16, 2012Aspirant
2 things you can try change the Port for Transmission's web interface to 9099 see if that makes any difference, if not disable transmission by unticking box in top left corner and click save bottom right corner then click edit settings.json scroll down and change "rpc-authentication-required": false, click save enable transmission you should not need to enter user and password now see if you can access transmissions interface.
