mesteele101
Oct 30, 2013Tutor
Configuring Automatic 1.1.1 for x86 with Transmission 3.00.3
I am having problems configuring Automatic x86 1.1.1 for my ShowRSS feed using Transmission 3.00.3 as my bittorrent client. I can see some of this, but I'm lost with some of it. I need clarification o...
salvationtower
Jan 25, 2015Aspirant
Hi There,
Just read through guide and added all the options, as previous post said is there a way to check if Automatic is parsing the RSS Feed? / or if you have a feed configured correctly to check if it is reading it? (ie a log file)
(I went through this process when i first got my ReadyNAS, and gave up and couldn't figure it out , so am having another attempt)
do you need to use the filter parameters? (My ShowRSS Feed only populates the shows that I want, so i don't need to filter anything out)
Cheers
Dave
Cheers
Dave
