pcutler's avatar
pcutler
Couch potato port?
Hi,
First, thanks to WhoCares? for all of the great addons.
I installed Python, SABNZBD, Couch Potato and Sick Beard last night. Sick Beard is working great and sees SABNZBD.
Couch Potato does not, and I see in the logs:
16:50:25 INFO [ app.lib.cron.yarr] Finished search.
16:50:25 ERROR [ app.lib.sabNzbd] Unable to connect to SAB.
16:50:25 INFO [ app.lib.sabNzbd] URL: http://localhost:2753/sabnzbd/api?apikey=MYAPIKEY
Can anyone confirm that port 2753 is correct? Or should I change the setting localhost:2753 to something other than localhost? (Changing it to the IP of my ReadyNas results in the same error)
Thanks!
  • Strange. Can you try using port 2708 and see if that fixes the problem ?
    -Stefan
  • Looks like port 2708 did the trick - thanks for the quick response!
    18:51:37 INFO [ app.lib.cron.yarr] Finished search.
    18:51:37 INFO [ app.lib.sabNzbd] NZB sent to SAB successfully.
  • pcutler wrote:
    Hi,
    Thanks!
    Very nice!Thank you for sharing!!!
  • I thought 2708 and 2753 ports worked for me but i forgot i was connecting trough my local network (wifi), any port i choose works inside my local network, but i can't find one to work for accessing couchpotato trough qouch in 3G, sabnzbd and sick beard works like a charm even in 3G, i can add nzb via qouch.
    Anyone succedded accessing couchpotato from the outside world ?
ProSupport for Business
