erikkramer
Sep 11, 2011Aspirant
CouchPotato and SickBeard
I'd like to share with you the way I got CouchPotato and SickBeard to work on my ReadyNAS Duo. It's FYI and please inform me if I'm abusing my ReadyNAS too much. My goal was to get both programs wo...
mdgm-ntgr
Jan 05, 2012NETGEAR Employee Retired
If you have the skills to install stuff like this via the command line then go for it.
The add-ons were created using http://www.readynas.com/sdk. Advantage of addons is not just the web-interface but also easy install on multiple systems. With add-ons, the developer does testing to check if it works, when you install stuff yourself manually you do the testing and checking to make sure it works, but it does give you the increased flexibility to configure things how you like which may not always be the same as how an add-on developer chooses to configure things.
