erikkramer
Sep 11, 2011Aspirant
CouchPotato and SickBeard
I'd like to share with you the way I got CouchPotato and SickBeard to work on my ReadyNAS Duo. It's FYI and please inform me if I'm abusing my ReadyNAS too much.
My goal was to get both programs working with Transmission, since I'm not a big newsgroup user. Using RAIDiator 4.1.7, Windows 7 and putty.
SSH into the readynas and install the sqlite thingy:
Next, install python:
I also had to install pysqllite (I put it in /src/root):
Then, download Couchpotato from https://github.com/RuudBurger/CouchPotato. Extract it and copy it to somewhere on the ReadyNAS, I used /home/couchpotato.
Now when you run:
it starts and you can reach it on http://[ip]:5000
To get it to start on booting the readynas I changed the initd script that comes with couchpotato to:
named the script couchpotato and copied it to /etc/init.d. Then performed these steps:
It still doesn't start on boot, though, so I added the line below to /etc/frontview/addons/addons.conf:
and added COUCHPOTATO=1 to /etc/default/services.
And now it works!
Sickbeard worked exactly the same, but I had to install cheetah beforehand. And I changed the startup script (in /etc/init.d/sickbeard) to:
P.S.
I'm probably abusing my ReadyNAS a little, by not using http://www.readynas.com/forum/viewtopic.php?f=47&t=52246 or http://www.readynas.com/forum/viewtopic.php?f=47&t=51609. But so far I've not found performance or resource issues. Another downside may be missing the ability to enable/disable the services from the frontview panel.
P.P.S.
While I was editing /etc/default/services I noticed that TRANSMISSION=0! Which makes sense, cause it didn't start on boot. So I set it to TRANSMISSION=1 and now also transmission auto-starts on boot.
Sources:
http://iandykes.blogspot.com/2010/10/install-python-26-on-readynas-nv.html
http://www.thibernet.com/442-install-sabnzbd-on-a-readynas-duo
http://www.ainer.org/couch-potato-install-setup-configuration-guide-for-ubuntu-linux-mint/2
http://sickbeard.com/forums/viewtopic.php?f=4&t=689
http://blog.vacs.fr/index.php?post/2009/03/21/Connecting-to-a-ReadyNAS-duo-using-SSH%3A
http://forums.sabnzbd.org/viewtopic.php?f=1&t=1668&start=15
http://www.readynas.com/forum/viewtopic.php?f=35&t=20829
http://www.mstuttle.com/2010/07/27/couchpotato/
http://hd420p.wordpress.com/guides/usenet-guides/part-two-adding-couchpotato/
http://gathering.tweakers.net/forum/list_messages/1438396/20
http://www.ainer.org/sick-beard-install-setup-configuration-guide-for-ubuntu-linux-mint
http://www.readynas.com/forum/viewtopic.php?f=36&t=50342
http://www.readynas.com/forum/viewtopic.php?p=77106#p77106
apt-get -y install sqlite
apt-get -y install libsqlite3-dev
LDFLAGS='-L/usr/local/lib'
CPPFLAGS="-I/usr/local/include"
cd /root/src
wget http://www.sqlite.org/sqlite-autoconf-3070400.tar.gz
#wget http://www.sqlite.org/sqlite-autoconf-3070500.tar.gz
gunzip -d -c sqlite-autoconf-3070400.tar.gz | tar xf -
cd sqlite-autoconf-3070400
./configure --build=sparc-linux
# The following takes a long time
make && make install
apt-get update
apt-get install libc6-dev
apt-get install gcc
apt-get install gdb
apt-get install libtag1-dev
apt-get install uuid-dev
apt-get install libssl-dev
apt-get install zlibc
apt-get install zlib1g-dev
mkdir /root/src/
cd /root/src/
wget ftp://ftp.gnome.org/cdimage/snapshot/Debian/pool/main/c/coreutils/coreutils_5.2.1-2_sparc.deb
dpkg-deb -x coreutils_5.2.1-2_sparc.deb .
wget http://www.python.org/ftp/python/2.6.6/Python-2.6.6.tgz
gzip -d Python-2.6.6.tgz
tar xf Python-2.6.6.tar
cd Python-2.6.6
make
make install
wget http://pysqlite.googlecode.com/files/pysqlite-2.6.3.tar.gz
gzip -d pysqlite-2.6.3.tar.gz
tar xf pysqlite-2.6.3.tar
cd pysqlite-2.6.3
python setup.py build_static install
cp /shared/couchpotato /home
Now when you run:
python /home/couchpotato/CouchPotato.py -d
#! /bin/sh
### BEGIN INIT INFO
# Provides: CouchPotato application instance
# Required-Start: $all
# Required-Stop: $all
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: starts instance of CouchPotato
# Description: starts instance of CouchPotato using start-stop-daemon
### END INIT INFO
############### EDIT ME ##################
# path to app
APP_PATH=/home/couchpotato
# path to python bin
DAEMON=python /home/couchpotato/CouchPotato.py -d
# startup args
DAEMON_OPTS=" CouchPotato.py -q"
# script name
NAME=couchpotato
# app name
DESC=CouchPotato
# user
RUN_AS=root
PID_FILE=/var/run/couchpotato.pid
############### END EDIT ME ##################
test -x $DAEMON || exit 0
set -e
case "$1" in
start)
echo "Starting $DESC"
start-stop-daemon $RUN_AS --start --quiet --pidfile "$PIDFILE" --make-pidfile --exec "$DAEMON" -- $OPTIONS &>/dev/null
stop)
echo "Stopping $DESC"
start-stop-daemon --stop --pidfile $PID_FILE
restart|force-reload)
echo "Restarting $DESC"
sleep 15
start-stop-daemon -d $APP_PATH -c $RUN_AS --start --background --pidfile $PID_FILE --make-pidfile --exec $DAEMON -- $DAEMON_OPTS
N=/etc/init.d/$NAME
echo "Usage: $N {start|stop|restart|force-reload}" >&2
exit 1
esac
exit 0
sudo chmod 755 /etc/init.d/couchpotato
sudo chown root.root /etc/init.d/couchpotato
sudo update-rc.d couchpotato defaults
COUCHPOTATO!!Couchpotato!!0.1!!sudo /etc/init.d/couchpotato start!!sudo /etc/init.d/couchpotato stop
And now it works!
#! /bin/sh
# Author: daemox
# Basis: Parts of the script based on and inspired by work from
# tret (sabnzbd.org), beckstown (xbmc.org),
# and midgetspy (sickbeard.com).
# Fixes: James (ainer.org), Tophicles (ainer.org), croontje (sickbeard.com)
# Contact: http://www.ainer.org
# Version: 3.0
### BEGIN INIT INFO
# Provides: sickbeard
# Short-Description: starts and stops sick beard
# Description: Sick Beard is an Usenet PVR. For more information see:
# http://www.sickbeard.com
### END INIT INFO
#Required -- Must Be Changed!
USER="root" #Set Linux Mint, Ubuntu, or Debian username here.
#Required -- Defaults Provided (only change if you know you need to).
HOST="127.0.0.1" #Set Sick Beard address here.
PORT="8081" #Set Sick Beard port here.
#Optional -- Unneeded unless you have added a Username and Password to Sick Beard.
SBUSR="" #Set Sick Beard Username (if you use one) here.
SBPWD="" #Set Sick Beard Password (if you use one) here.
#Script -- No changes needed below.
case "$1" in
start)
#Start Sick Beard and send all messages to /dev/null.
cd /home/sickbeard
echo "Starting Sick Beard"
sudo -u $USER -H nohup python /home/sickbeard/SickBeard.py -q > /dev/null 2>&1 &
stop)
#Shutdown Sick Beard and delete the index.html files that wget generates.
echo "Stopping Sick Beard"
wget -q --user=$SBUSR --password=$SBPWD "http://$HOST:$PORT/home/shutdown/" --delete-after
sleep 6s
echo "Usage: $0 {start|stop}"
exit 1
esac
exit 0
P.S.
P.P.S.
Sources:
- erikkramerAspirant
polux400 wrote:
Thank you so much erikkramer
polux
My pleasure!
