Grouty
Apr 29, 2012Tutor
"Could not connect to tracker" message
Hi Guys, I'm sure I'm missing something obvious but I have been trying this for ages without success. I am plagued by this message: Could not connect to tracker. I cannot get Transmission (v2.42) t...
JarnoG
Apr 30, 2012Guide
It might be that your NAS does not have access to your internet connection. This can be caused by faulty DHCP settings. If you go to Frontview->Network->Interfaces you can check those settings. In most cases, all the settings should be on automatic.
You can check if your NAS can connect to the internet by checking for updates by going to Frontview->System->Update and press the "check for updates" button on the remote-tab.
This is probably not related to your problem, but your download dir might give some problems. You've got
"download-dir": "/media/BitTorrent/",Which should probably be
"download-dir": "/c/media/BitTorrent/",
