dgriffin1
Oct 10, 2011Aspirant
Create NAS share
How can I create a share on the NAS for the Shared folder in the ELC? I would like to backup certain files to this loaction via the Remote Rsync server. Is this possible?
dgriffin1
Oct 13, 2011Aspirant
The example syntax did not work in the Frontview backup screen. Test connection fails. I am using the Remote Rsync server as the destination. Host is the IP of the NAS. In the path option only \backup\ will work when testing the connection but the backup will not function. I states it is progress but not files are tranfered.
I try the example syntax you sent of c/backup/ but the connection fails.
any ideas?
any ideas?
