eton
Apr 20, 2012Luminary
DDClient - by WhoCares - I hope this one will work
Finally a new dyn dns client, D(yn)D(ns)Client, thanks WhoCares: viewtopic.php?f=47&t=62337 DnsOMatic - didn't work for all hosts (as promised) and used dum constant updates and we got warnings f...
boogerme
Jul 25, 2012Aspirant
I have a problem, I registered a free no-ip host, installed the client and set this config:
the host works correctly, the problem is that it doesn't seem to update the IP address.
I tried to change my IP but the new one has not been sent to no-ip, and I had to manually update it.
where's the problem? thanks.
use=web, web=checkip.amazonaws.com \
protocol=noip, \
login=username, \
password=password, \
myhost.no-ip.org
