eton
Apr 20, 2012Luminary
DDClient - by WhoCares - I hope this one will work
Finally a new dyn dns client, D(yn)D(ns)Client, thanks WhoCares: viewtopic.php?f=47&t=62337 DnsOMatic - didn't work for all hosts (as promised) and used dum constant updates and we got warnings f...
boogerme
Jul 25, 2012Aspirant
I obviously edited them just for publicly posting the config here. :D
I was also not use if the correct login is just "username" or "[email protected]", I tried both but again it doesn't seem to work.
also, can you shed some light about the commas at the end of each entry, before the backslash? in which entries they should be used?
thanks!
thanks!
