eton
Apr 20, 2012Luminary
DDClient - by WhoCares - I hope this one will work
Finally a new dyn dns client, D(yn)D(ns)Client, thanks WhoCares: viewtopic.php?f=47&t=62337 DnsOMatic - didn't work for all hosts (as promised) and used dum constant updates and we got warnings f...
boogerme
Jul 25, 2012Aspirant
Alright, thank you.
so, my config should be correct, right?
as I said the DNS hosts works, the only problem is that it doesn't check/update the IP address and I have to manually update it (through no-ip web interface).
