eton
Apr 20, 2012Luminary
DDClient - by WhoCares - I hope this one will work
Finally a new dyn dns client, D(yn)D(ns)Client, thanks WhoCares: viewtopic.php?f=47&t=62337 DnsOMatic - didn't work for all hosts (as promised) and used dum constant updates and we got warnings f...
eton
Nov 14, 2012Luminary
Ok DynDNS.org seems to update correctly, though we still might need a work around for the 30 days thing.
But No-IP is much harder.
This might be useful for the 30 days limitations workaround:
http://www.dyncommunity.com/questions/9 ... pdate.html
And here is something for No-IP:
http://www.astaro.org/gateway-products/ ... s-tab.html
ddclient checks /var/cache/ddclient/ddclient.cache against the ip it get from http://checkip.dynsdns.org. If the ip address is the same, it won't update even though your http://yourhost.dyndns.org resolves to a different ip address.
