eton
Apr 20, 2012Luminary
DDClient - by WhoCares - I hope this one will work
Finally a new dyn dns client, D(yn)D(ns)Client, thanks WhoCares: viewtopic.php?f=47&t=62337 DnsOMatic - didn't work for all hosts (as promised) and used dum constant updates and we got warnings f...
eton
Nov 19, 2012Luminary
Thanks Sandshark!
If you like to use a secure address, why not use:
Now, my DDclient settings looks like this. The DynDNS.org settings works, yes without skip=, but it's probably more correct to have skip=.
But I am not sure if I am doing this right with two services.
Note: I've seen that some of the older setups for No-IP uses protocol=dyndns2.
https://dynupdate.no-ip.com/nic/updateSource: http://www.no-ip.com/integrate/request
pid=/var/run/ddclient.pid, \
## DynDNS
protocol=dyndns2, \
use=web, web=checkip.dyndns.com, \
server=members.dyndns.org, \
login=my_nick, \
password='my_password' \
my_domain.dyndns.org
## No-IP
daemon=600, \
ssl=yes, \
use=web, \
web=http://ip1.dynupdate.no-ip.com/, \
protocol=noip, \
server=https://dynupdate.no-ip.com/nic/update, \
login='my_email', \
my_domain.no-ip.org
