eton
Apr 20, 2012Luminary
DDClient - by WhoCares - I hope this one will work
Finally a new dyn dns client, D(yn)D(ns)Client, thanks WhoCares: viewtopic.php?f=47&t=62337 DnsOMatic - didn't work for all hosts (as promised) and used dum constant updates and we got warnings f...
eton
Jul 21, 2013Luminary
arnomc wrote: for DynDNS users that kept active their account (or new members using the basic free service offered by Dlink here : https://www.dlinkddns.com/login ; which is in fact operated by DynDNS), here is a page where to you can make an automatic settings file and it's working !! (you just have to change ###password### for you real password ... simple but i made the mistake lol).
https://account.dyn.com/entrance/?return=%2Ftools%2Fclientconfig.html
EDIT : you just have to check that the 'lines' are correct in their \ (and the carriage return) ; because the automatic config file obtained can have few mistakes (that's why i didn't pay attention on changing password). Just rearrange it, it's easy.
Thanks!
But today I got this from dyn.com (former DynDNS.org):
If you would like to maintain your free Dyn account, you must log into your account once a month. Note that using an update client will no longer suffice for this monthly login. You will still continue to get email alerts every 30 days if your email address is current. Failure to login once per month will result in expiration and loss of your hostname.
They are forcing their active users to become paying customers. In other words dyn.com is dying.
