eton
Apr 20, 2012Luminary
DDClient - by WhoCares - I hope this one will work
Finally a new dyn dns client, D(yn)D(ns)Client, thanks WhoCares: viewtopic.php?f=47&t=62337 DnsOMatic - didn't work for all hosts (as promised) and used dum constant updates and we got warnings f...
Sandshark
Oct 01, 2013Sensei
For anyone who is sill looking to use DDClient with No-IP, I found that the configuration above doesn't work quite right. It doesn't retrieve your IP address correctly. It seemed to work for me initially, because it already had the right IP address. This is one that works:
Note that this does not have all the backslashes at the ends of the lines. They were part of the problem.
You can also debug whether it is working if you have SSH access, using the following command string:
## no-ip single host update
daemon=600
ssl=yes
use=web, web=ip1.dynupdate.no-ip.com/
protocol=noip,
server=dynupdate.no-ip.com,
login='my_email'
password='my_password'
my_domain.no-ip.org
sudo ddclient -daemon=0 -debug -verbose -noquiet
