eton
Apr 20, 2012Luminary
DDClient - by WhoCares - I hope this one will work
Finally a new dyn dns client, D(yn)D(ns)Client, thanks WhoCares: viewtopic.php?f=47&t=62337 DnsOMatic - didn't work for all hosts (as promised) and used dum constant updates and we got warnings f...
herko1
Jan 29, 2014Aspirant
So decided to take up the challenge and installed the Enable Root SSH add-on, did
So, I started learning a bit about what could be going on. And I found that it's probably got something to do with the /etc/apt/sources.list file, where I need to add a bunch of new sources. However, to be able to edit that file, I need to install a text editor like vim or nano or pico or vi. I've tried them all, but all of them give me the error:
So, how do I add the sources needed to edit the sources list? I'm in a bit of a loop here, and I can't find a solution yet. Any help is greatly appreciated!
Herko
apt-get update
apt-get install ddclient
Reading package lists... Done
Building dependency tree... Done
E: Couldn't find package ddclient
Herko
