eton
Apr 20, 2012Luminary
DDClient - by WhoCares - I hope this one will work
Finally a new dyn dns client, D(yn)D(ns)Client, thanks WhoCares: viewtopic.php?f=47&t=62337 DnsOMatic - didn't work for all hosts (as promised) and used dum constant updates and we got warnings f...
fastfwd
Jan 29, 2014Virtuoso
herko wrote: it's probably got something to do with the /etc/apt/sources.list file, where I need to add a bunch of new sources.
Your current sources.list file contains a line that begins with a "#" character. Removing the "#" character from that line is probably all you need to do.
herko wrote: However, to be able to edit that file, I need to install a text editor like vim or nano or pico or vi.
You should already have vi. Try this:
vi /etc/apt/sources.list
To exit vi without saving changes you've made, hit ESC and then type :q! -- more vi instructions are here: http://www.lagmonster.org/docs/vi.html
Once you've changed your sources.list file, do another apt-get update, then try apt-get install ddclient again.
Afterward, you can install nano by typing apt-get install nano ... But learning at least the basics of vi is worthwhile because it'll be available on every Unix you encounter.
