eton
Apr 20, 2012Luminary
DDClient - by WhoCares - I hope this one will work
Finally a new dyn dns client, D(yn)D(ns)Client, thanks WhoCares: viewtopic.php?f=47&t=62337 DnsOMatic - didn't work for all hosts (as promised) and used dum constant updates and we got warnings f...
Sandshark
Jun 03, 2014Sensei
Looking back at a few threads I've posted in in case they need updates.
If anyone is still looking for this add-on, it's at https://rnxtras.com/addons/ddclient-readynas-4-x86.
I also found out what the "skip=" is all about in the configuration. If the site you are using to determine your IP address returns anything other than just the address, it's used to tell DDClient what to skip to get to the address. The one in my example (second one that works) does return just the address, so the "skip=" is not necessary.
