chokobanana
Jul 27, 2013Guide
Default login/password for Transmission on OS 6.x
Hello, I've found all kinds of combinations but none work! admin:password1 seems to be the most commonly used. It does not work with OS 6.0.8 though. How do I log in?
stgeorge
Aug 24, 2013Guide
Sorry if this is posted in an inappropriate location...
I'm trying to better understand the most efficient method of running a p2p client (on a readynas device) through a vpn connection. Some options are: 1) utilize a router that can route all internet or possibly just all p2p traffic (from either the BitTorrent client which came standard on the Duo v1 or traffic from a Transmission (or similar) client) through a vpn server internet connection, or 2) utilize an add-on to connect either the entire readynas network connection or to configure a similar p2p client running on the readynas to direct this traffic through a tunnel to a vpn server.
Most vpn server internet connection services offer up free client software to direct traffic from a pc device running on your LAN to their server (and the routers will generally support vpn 'passthrough' connections like that), but I am struggling with keeping the relevant p2p client running on my nas while at the same time flowing its traffic through a vpn service.
Thanks for the assistance.
