bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I log into my account on the dnsomatic website, it just sits there saying "Waiting for first update" for both my dyndns and opendns account. Any way to confirm its proper installation and usage?
Thanks!
PS I forgot to mention I installed the 1.1 version that was updated a few hours ago (from 1.0 early this morning).
Thanks!
- super_poussinVirtuosoI will provide a new version to day if I have enough time (for NV+/DUO/1100 ) cause the actual version works fine on PRO
I need to do more test - RWrightAspirant
super-poussin wrote: I will provide a new version to day if I have enough time (for NV+/DUO/1100 ) cause the actual version works fine on PRO
Thanks super-poussin.
I've also discovered that DNSOMatic version 1.4 does not seem to stop running when stopped from the add-ons page in FrontView. I thought I'd shut it down this morning but having just checked the logs, there are entries for the whole day. - dl78Aspirant
RWright wrote: dl78 wrote: How do you open a ssh connection to run the script ?
Is there any specific add-on for the Duo to open the ssh ?
For ssh access:
http://www.readynas.com/?page_id=617
Check out the "Shell Access Patches" at the bottom.
Many thanks RWright for your help.
Now I was able to run the script "sh /c/addons-scripts/DnsOMatic/dnsomatic" and it works once each time run manually but the DynDNS IP is not changed.
I have similar log as you got:
Sat May 9 20:00:01 CEST 2009 NO Internet IP : exiting
Sat May 9 20:10:01 CEST 2009 NO Internet IP : exiting
Sat May 9 20:13:45 CEST 2009 : found: 82.235.xxx.xx cached IP:
Sat May 9 20:15:01 CEST 2009 NO Internet IP : exiting
Sat May 9 20:20:01 CEST 2009 NO Internet IP : exiting
Sat May 9 20:25:01 CEST 2009 NO Internet IP : exiting - RWrightAspirant
Hi super-poussin
Is there any news on an update for this ?
Many thanks - sergiosatAspirantI found the trick for the Duo:
- In general the cron environment is not the same as the shell environment, therefore some paths in the cron environment are not set as the normal shell.
- In this case the path to launch "curl" command is not set and the command does not work
- In order to have the curl command correctly in the script is mandatory to add the path before the curl command
- Changing the line:
IP=$(curl -s http://myip.dnsomatic.com/)
in
IP=$(/usr/local/bin/curl -s http://myip.dnsomatic.com/)
and
RETURN=$(curl -k -s https://${USER}:${PASS}@updates.dnsomatic.com/nic/update?hostname=${HOSTNAME}&myip=$IP&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG)
in
RETURN=$(/usr/local/bin/curl -k -s https://${USER}:${PASS}@updates.dnsomatic.com/nic/update?hostname=${HOSTNAME}&myip=$IP&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG)
is enough to have the script correctly working on the Duo.
I kindly ask super-poussin to update the addon.
Hope the above is of any help.
Regards
Sergio - super_poussinVirtuosoThank you Sergio 1.5 is out
it was done for OpenDNSUpdater and not DNSOMATIC
Shame on me I forget the basic and not comparing both - dl78Aspirant
super-poussin wrote: Thank you Sergio 1.5 is out
Thanks All for your help.
However, I tried version 1.5 but my DynDNS still not changed properly.
I checked with "tail -f /var/log/DNS-O-Matic.log" and got the following:
Mon May 25 18:10:01 CEST 2009 : found: 82.235.xxx.xx cached IP: 82.235.xxx.xx
Mon May 25 18:15:01 CEST 2009 : found: 82.235.xxx.xx cached IP: 82.235.xxx.xx
Mon May 25 18:20:02 CEST 2009 : found: 82.235.xxx.xx cached IP: 82.235.xxx.xx
Mon May 25 18:30:02 CEST 2009 : found: 82.235.xxx.xx cached IP: 82.235.xxx.xx
Mon May 25 18:35:01 CEST 2009 : found: 82.235.xxx.xx cached IP: 82.235.xxx.xx - super_poussinVirtuosoremove /tmp/oldip.DNS-O-Matic or reinstall the add-on
- dl78AspirantHello,
I didn't find any "/tmp/ folder.
I uninstalled Addon and deleted /addons-scripts/DnsOMatic/ then reinstalled version 1.5 and reboot after modifying the dnsomatic file. But it's the same issue.
I don't understand what is going wrong. - super_poussinVirtuosoall the nas have a /tmp
the /tmp is 1777 rights if you did not have a /tmp on your nas , you wil not be able to upgrade a NAS or install addons
caan you please redo the installation of the addon it will clean all the old files
