lezardsouffle
Apr 17, 2015Aspirant
Dropbox add-on for Ultra6 linked but not syncing
We have a ReadyNAS Ultra 6 (loaded with four 2TB drives in RAID5 and containing about 1.1TB of data) that we recently updated to firmware 4.2.27. We installed the Dropbox add-on from rnxtras.com and ...
WhoCares_
Apr 28, 2015Mentor
Since you're on ReadyNAS OS4, the app will *not* tell you it's current state and thus won't tell you when syncing is finished (I'm working on that though). As for the "Enable Auto Update" feature: This isn't very realiable for Dropbox doesn't seem to offer automated updates as regularly as they release new versions. But you can always check the "Current Stable Version" and if it's newer than the version currently running on your ReadyNAS, you can do a manual upgrade. The same is true for the the testing versions, but opposed as to the stable versions there may be no easy downgrade path back to a stable release.
-Stefan
-Stefan
