peterdgreenway
Nov 27, 2011Aspirant
Dropbox Addon Causing Continual Fsck On Re-Boot <- Be Warned
All My ReadyNAS Pro has been happily booting without incident for months and then in the last couple of weeks it is doing a fsck virtually every boot. A little investigation into the fsck.log and ...
WhoCares_
Nov 27, 2011Mentor
I just tried on three different ReadyNAS systems and none of those showed that behavior and I can't find a fsck.log on any of those either, so a little bit more information would be helpful. Do you use the timer function to shut down the ReadyNAS or do you shut it down using the menu entry in Frontview? Also an excerpt from the fsck.log as well as relevant parts from /var/log/messages could shed some light on what is happening.
-Stefan
-Stefan
