peterdgreenway
Nov 27, 2011Aspirant
Dropbox Addon Causing Continual Fsck On Re-Boot <- Be Warned
All My ReadyNAS Pro has been happily booting without incident for months and then in the last couple of weeks it is doing a fsck virtually every boot. A little investigation into the fsck.log and ...
peterdgreenway
Nov 28, 2011Aspirant
Hi Stefan
I was sort of assuming that everything would be shutdown gracefully automatically when the ReadyNAS closes down, obviously not. All of the files referenced for fixing were in the Dropbox cache:
***** File system check performed at Sun Nov 27 06:55:49 WET 2011 *****
fsck 1.41.14 (22-Dec-2010)
e2fsck 1.41.14 (22-Dec-2010)
/dev/c/c contains a file system with errors, check forced.
Pass 1: Checking inodes, blocks, and sizes
Inode 321953876 has a bad extended attribute block 2575630464. Clear? yes
Inode 321953876, i_blocks is 120, should be 112. Fix? yes
Inode 321953878 has a bad extended attribute block 2575630464. Clear? yes
Inode 321953878, i_blocks is 128, should be 120. Fix? yes
Inode 321953883 has a bad extended attribute block 2575630464. Clear? yes
Inode 321953883, i_blocks is 136, should be 128. Fix? yes
Inode 321953886 has a bad extended attribute block 2575630464. Clear? yes
Inode 321953886, i_blocks is 144, should be 136. Fix? yes
Inode 321953887 has a bad extended attribute block 2575630464. Clear? yes
Inode 321953887, i_blocks is 152, should be 144. Fix? yes
Inode 321953890 has a bad extended attribute block 2575630464. Clear? yes
Inode 321953890, i_blocks is 152, should be 144. Fix? yes
Inode 321953891 has a bad extended attribute block 2575630464. Clear? yes
Inode 321953891, i_blocks is 160, should be 152. Fix? yes
Inode 321953892 has a bad extended attribute block 2575630464. Clear? yes
Inode 321953892, i_blocks is 168, should be 160. Fix? yes
Inode 321953899 has a bad extended attribute block 2575630464. Clear? yes
Inode 321953899, i_blocks is 184, should be 176. Fix? yes
Inode 321953903 has a bad extended attribute block 2575630464. Clear? yes
Inode 321953903, i_blocks is 184, should be 176. Fix? yes
Inode 321953905 has a bad extended attribute block 2575630464. Clear? yes
Inode 321953905, i_blocks is 272, should be 264. Fix? yes
Inode 321953906 has a bad extended attribute block 2575630464. Clear? yes
This is from a couple of the entries:
find /c/Dropbox -xdev -inum 321953868 -print
/c/Dropbox/.dropbox.cache/2011-11-26/LastSession (deleted 4ed14d9f-a91b-545bf1b9).plist
find /c/Dropbox -xdev -inum 321953906 -print
/c/Dropbox/.dropbox.cache/2011-11-26/LastSession (deleted 4ed150aa-1f661-b3eee648).plist
Hope this helps.
Peter
Hope this helps.
Peter
