monstertruck
Sep 11, 2012Aspirant
Dropbox not syncing
Hi, I have Dropbox 1.4.17 installed on my Readynas Ultra 4 running radiator 4.2.21. For a couple of days everything ran smoothly, but then suddenly it stopped syncing. I've tried restarting the ...
monstertruck
Sep 13, 2012Aspirant
mdgm wrote: DId you install this add-on?: http://www.readynas.com/forum/viewtopic.php?f=48&t=58647
If so do you have the latest version (currently 0.9.7) of the add-on installed?
If you didn't install this add-on how did you install Dropbox?
Yes, this is the add-on (latest version) that is installed.
