beaumonr
Sep 18, 2024Aspirant
Enabling SSH access on Readynas Ultra 2
Hi, I've got two old Readynas ultra 2's which I am replacing with 2 new Synology DS224's mainly due to age and the declining support. In order to migrate the data I want to run some Rsynch routin...
- Sep 18, 2024
Note I instructed you to log in as root with the NAS admin password.
beaumonr
ok, downloaded the add as instructed, installed it restarted the readynas, checked the logs which tell me that SSH root access has been enabled with the same password as my admin account.
From the same pc which I've logged into the management page I then try an SSH connection. It initially warns me about the lack of keys and gives option to continue, it then permanently adds the IP address to the list of known hosts.
I try and login it requests the password I enter it then it appears to open the connection I can see the name of the server and the ip address of the pc I,m trying to access it from. but then it closes the connection.
heres the screenshot.
I've not idea why and further help appreciated
thanks
Sep 18, 2024Guru - Experienced User
- beaumonrSep 18, 2024Aspirant
Ahaaaa yes I didn't read it properly sorry. Obviously I couldn't see the wood for the trees.
In fact I've just done it by reading a separate post elsehwere and I've come back to let you know.. only to see your reply....
I was feeling all successful..... but then...back down to earth. hahahahaaa
Thanks so much ... right now to try and get the Rsynch working ... I might be back 🙂
cheers
Rob
