bob_m10's avatar
bob_m10
Enable Access Point Mode
Hi All,
I have the R6050 and confused as to the purpose of the Enable Access point mode?  In my case I beleive I am already using the R6050 as an AP but not using this option.  I  connect one of LAN ports on the R6050 back to my ISP Gateway's LAN  port. DHCP comes from the ISP's Gateway, I have disabled DHCP on the R6050. All wired and wireless devices on the LAN share the same IP space,  192.168.1.x.  So what is the purpose of Access point mode and why would you want to use it?  Thanks
  • The Access Point mode would be a quick cut to reconfigure everything, sometimes even the WAN/Internet port (some newer routers allow using all Ethernet ports in AP mode - but not sure about yours), disabling the DHCP server, disabling the routing/Internet, ... and get a DHCP client active so the device does get an IP address assigned by your other DHCP server.
  • schumaku's avatar
    schumaku
    • bob_m10's avatar
      bob_m10
      So basically the same thing I did manually it would do automatically?  thanks
      • schumaku's avatar
        schumaku
        Don't know how you reconfigure the router on the LAN to be a DHCP client, but yes.
