NASty1's avatar
NASty1
error message from RN314
My RN314 began informing me that Disk two of my array failed its' disk test.  I replaced the disk with a new one, but about two weeks later, I recieved the same status warning as before.  The first h...
  • StephenB's avatar
    Mar 26, 2019
    Well, the error means that the system crashed at that location.
    What firmware are you running?
    Do you have a backup of your data?  If not, if the system reboots you should definitely take care of that.
    If you purchased (new) between 1 June 2014 and 31 May 2016 you have lifetime chat support via my.netgear.com.  If that's the case, you should definitely use that service.
ProSupport for Business
