jonas914
Oct 07, 2013Tutor
Failed backups again
2x ReadyNAS Pro4 - One local, one offsite (which is a pain to get access to!) All 4 replicate jobs have been running perfect for months after moving the start times around to get around timeouts in t...
jonas914
Sep 04, 2014Tutor
It happened again this week where NAS2 just disappeared. I can't get to it physically (its offsite), but when I asked someone to check it, it is powered on and looks normal on the display. Rebooting it got to show up in Replicate again.
I added the port you suggested. We'll see what happens.
- Nathan95Sep 25, 2015Aspirant
Did you get to the bottom of this?
Sorry I know its bit of a late reply but I have been searching for information on this as I am having exactly the same issue. My NAS boxes are both running OS6 and work on the LAN but when one is taken offsite and reconnected to a network point (also showing online on the replication portal) it then fails with exit code 30.
Let me know if you ever got yours sorted,
Thanks,
Nathan Leather
