mefisto4
Jun 04, 2009Aspirant
Firebird SQL server
Hi i'm looking for help in the Firebird SQL. I do not know what I have to run Firebird SQL ReadyNAS NV +. What add-on to use? Thanks
super_poussin
Jun 04, 2009Virtuoso
not sure it will comple correctly on sparc
configure: error: cannot guess build type; you must specify one
If the result of the above commands looks okay to you, go to the directory
source in the ICU distribution to build ICU. Please remember that ICU needs
GNU make to build properly...
The Firebird2 package has been configured with the following options:
Architecture : ClassicServer
Debug : disabled
64 bit I/O for 32-bit platforms : enabled
Raw devices : enabled
Lock manager : enabled
Service name : gds_db
Service port : 3050
GPRE modules : c_cxx.cpp
Install Dir : /usr/local/firebird
r2-d2:/Develop/firebird-src/Firebird-2.1.2.18118-0#
