carlos215
Jan 17, 2022Aspirant
Flashing Error LED - RN2120
Hello, We got a flashing red on the error LED on a ReadyNas 2120. Im not sure what the error means since all of the HD's lights are blue and not showing any errors. I cannot connect to the NAS an...
Sandshark
Jan 18, 2022Sensei
What does RAIDar show?
- carlos215Jan 18, 2022Aspirant
It is not showing up in RAIDar, I also tried ReadyCloud and nothing showed up
- JeraldMJan 26, 2022NETGEAR Employee Retired
Hi carlos215,
It's most likely that it is a hardware fault. Were there any events that might have caused the issue?
Also, have you tried contacting support? If not, please click here to create a case and contact support.
JeraldM
NETGEAR Community Team
- SandsharkJan 27, 2022Sensei
I agree it sounds like a hardware problem. But just in case, try removing all the drives (with power off, marking them so they go back where they belong later) and power on diskless. Does RAIDar then see the NAS and show a "No disks" status?
