gibxxi
Nov 10, 2011Guide
HeadPhones 0.1.1 GUI port conflicts with Transmission...
Just a heads up really. But both add-ons run their web interface on port 8181. Easy enough to change transmission's port if your not running the "reverse SSL proxy" mod mentioned elsewhere on this ...
sphardy1
Nov 10, 2011Apprentice
That folder has nothing to do with configuring the Headphones application - the files you see enable Frontview to show the addons in its' configuration page.
To create an "alias" for your Wordpress install - create a .conf file in that folder with contents such as:
Restart the HTTP service and you should be able to access your site at: http://ip.address/wordpress
Alias "/wordpress" "/c/webroot/wordpress"
<Location "/wordpress">
Options FollowSymlinks -Indexes
Order allow,deny
Allow from all
DirectoryIndex redirect.html index.html index.php
</Location>
