gibxxi
Nov 10, 2011Guide
HeadPhones 0.1.1 GUI port conflicts with Transmission...
Just a heads up really. But both add-ons run their web interface on port 8181. Easy enough to change transmission's port if your not running the "reverse SSL proxy" mod mentioned elsewhere on this ...
WhoCares_
Nov 21, 2011Mentor
gibxxi wrote: i'm going to have to dive into headphones' configuration files and see if I can change it's port to something else. WhoCares, any chance of altering the port of your add-on for other people in the same boat?
Sorry for being late to reply. Actually what's the problem with just clicking on the 'settings' link in HeadPhones menu bar and changing the port to whatever suits you best? Does the setting not stick? The only downside to this would be that you can't use the 'Use HeadPhones' link from within Frontview's add-on page anymore but otherwise all should be fine. Of course the standard port could be changed in a future version of the add-on but I don't think this change warrants a new release.
-Stefan
