gibxxi
Nov 10, 2011Guide
HeadPhones 0.1.1 GUI port conflicts with Transmission...
Just a heads up really. But both add-ons run their web interface on port 8181. Easy enough to change transmission's port if your not running the "reverse SSL proxy" mod mentioned elsewhere on this ...
gibxxi
Mar 18, 2012Guide
You are right WhoCares. Wasn't aware at the time of making that post that the port could be changed from within the GUI. Another knee-jerk reaction to a problem. The issue for me was that because I already had Transmission running, I couldn't get the add-on to start to see that there was an option to change it's running port. Obviously stopping transmission, starting HeadPhones, THEN making the change would of solved the issue. Like I say, knee-jerk reaction. Apologies.
