DuBa
May 13, 2021Aspirant
Help adding a OK disk with SMART warnings
I have a HDD that got the SMART Raw Read Error Rate value set to 148 and Multi Zone Error Rate set to 1 after removing it from a secure data overwrite device without disabling the port first. It is a Western Digital WD30EFRX with about 9 months on time, but out of warranty due to it beeing a unused spare HDD for a few years.
I have done extensive testing by connecting it to PC's, servers and devices and the drive is operating correctly with no errors. I have checked it with WD's tool and it shows as OK. The Status / Health in the admin interface of the ReadyNAS 2100 v2 menu shows the drive as OK, but when connecting it to the ReadyNAS the log after a while shows "Newly added disk has failed SMART test. Please check disk 4.". I have however not found a way to clear this warning in the log and so it will not add the HDD to the volume.
I do not want to throw the disk out as it is working fine. There is currently no data on the NAS while I'm working on this.
Any ideas?
| SMART Attribute | |
| Raw Read Error Rate | 148 |
| Spin Up Time | 6008 |
| Start Stop Count | 18 |
| Reallocated Sector Count | 0 |
| Seek Error Rate | 0 |
| Power On Hours | 6579 |
| Spin Retry Count | 0 |
| Calibration Retry Count | 0 |
| Power Cycle Count | 18 |
| Power-Off Retract Count | 10 |
| Load Cycle Count | 87 |
| Temperature Celsius | 27 |
| Reallocated Event Count | 0 |
| Current Pending Sector | 0 |
| Offline Uncorrectable | 0 |
| UDMA CRC Error Count | 0 |
| Multi Zone Error Rate | 1 |
| ATA Error Count | 0 |
A SMART test isn't just reading SMART stats. If the disk is failing the SMART test then you shouldn't use the disk.
As you have the 2100 v2 (I assume that's what shows on the homepage of Frontview) and you have no data on the unit you might wish to consider putting OS6 on the unit.
The 2100 v2 can run OS6 (though unsupported) whereas the v1 cannot as the v1 has a 32-bit x86 CPU.
- mdgmVirtuoso
- DuBaAspirant
mdgm wrote:A SMART test isn't just reading SMART stats. If the disk is failing the SMART test then you shouldn't use the disk.
Well, the SMART status of the drive is OK and these parameters are generally not considered critical so this HDD should be fine to use for non-critical storage. If only ReadyNAS would let me. If it was increasing reallocated sectors counts or something like that, it would be a completely different thing.
But OS6 sounds like an interesting idea. Maybe that would work. I'll give it a try unless someone here thinks otherwise.
- DuBaAspirant
I upgraded to OS6 and so far it looks really good. It is currently syncing. It seems OS6 have better handling of SMART.
I will update here when the sync is completed and I have done some tests.
