Dave_Surtees
Dec 31, 2010Aspirant
Help! Stream from NAS to iPad with AirVideo App?
Hi, I just got my NAS set up and thought it would be great to wifi stream video to my iPad, I installed the app on the pad but it asks me for a IP address (so I enter that of the NAS) it also as...
embryo
Jan 03, 2011Aspirant
Unfortunately, you'll need to install AirVideo server on your PC and leave your PC on for this to work. To access the NAS content, you'll need to map a drive to the NAS on your PC, then add this to the list of folders you want to share out in the Air Video Server app. Then add the PC IP address in Air Video on the iPad. There are ways you can connect directly to the NAS (eg DLNA) but AirVideo will convert pretty much any file type on the fly.
Hope this helps.
Thanks.
Hope this helps.
Thanks.
