Dave_Surtees
Dec 31, 2010Aspirant
Help! Stream from NAS to iPad with AirVideo App?
Hi, I just got my NAS set up and thought it would be great to wifi stream video to my iPad, I installed the app on the pad but it asks me for a IP address (so I enter that of the NAS) it also as...
peterdgreenway
Jan 17, 2011Aspirant
Found this thread and would comment my experiences ...
+ Installed the Addon fine.
+ My iPhone found my Pro immediately and logged on
+ I get the same problem with everything being invalid when I try and play it
+ I also need to know if you can tell the Pro different folders to monitor ? Can't find how to do it anywhere and if anyone can enlighten me I would be very grateful
Update. 18th January 2011
You tell the add-on which folders to monitor by SSH ing into the ReadyNAS and editing the file readynas.properties
Syntax
Folder Label 1:/c/mymediafolder1, Folder Label 2:/c/mymediafolder2
Not the comma between each different location to scan.
Thanks
Syntax
Thanks
