Dave_Surtees
Dec 31, 2010Aspirant
Help! Stream from NAS to iPad with AirVideo App?
Hi, I just got my NAS set up and thought it would be great to wifi stream video to my iPad, I installed the app on the pad but it asks me for a IP address (so I enter that of the NAS) it also as...
mdgm-ntgr
Mar 27, 2011NETGEAR Employee Retired
super-poussin wrote:
dox1000 wrote:
super-poussin wrote: it should work on ultra, ultra is a x86_64 architecture
Does that mean it should not work on a pro then?
Dox
It works on pro too
Of the desktop x86 ReadyNAS, only the NVX and NVX Pioneer are 32-bit. All other desktop x86 models use the x86_64 architecture.
Bitzerj wrote: I have tried all the suggestions, have an Ultra, and still get the invalid files.
Do other addons install fine?
Bitzerj wrote: To be clear, the utility on the IPhone, IPAD, sees the server, sees the files, but all the files are tagged Invalid.
So the addon is installed on your NAS? If so, when editing the config were you sure to use an editor like Notepad++ as suggested (not ordinary Notepad as this mucks up the formatting)?
