Dave_Surtees
Dec 31, 2010Aspirant
Help! Stream from NAS to iPad with AirVideo App?
Hi, I just got my NAS set up and thought it would be great to wifi stream video to my iPad, I installed the app on the pad but it asks me for a IP address (so I enter that of the NAS) it also as...
zmalex
Apr 06, 2012Aspirant
Typhoon wrote:
kurfuer wrote: Hi,
had the same issue here showing only invalid files, but was able to fix it, at least for me :-)
This is the original ffmpeg path entry in the file /c/webroot/AirVideo/readynas.properties
path.ffmpeg = ./AirVideo/ffmpeg
This file is available in this directory, but nevertheless the ffmpeg plugin installed the ffmpeg to /usr/local/bin/ffmpeg
So I changed the path entry to
path.ffmpeg = /usr/local/bin/ffmpeg
and after a restart of the plugin I'm happy :D
Thank you so much for sharing this!! I did the same that you described and voila, it works!!! Finally! :) Thank you for your help!
This fix also worked for me. However the two ffmpeg version seem to be different.
/usr/local/bin/ffmpeg - 8302976 2012-03-31 08:27
./AirVideo/ffmpeg - 7973448 2010-10-29 22:35
I'm using a Ultra 4 Plus with RAIDiator 4.2.19
@Super-poussin: Any thoughts on this?
