Dave_Surtees
Dec 31, 2010Aspirant
Help! Stream from NAS to iPad with AirVideo App?
Hi,
I just got my NAS set up and thought it would be great to wifi stream video to my iPad,
I installed the app on the pad but it asks me for a IP address (so I enter that of the NAS) it also asks for a port? what do i use?
I know doubt have got this all wrong and there's probably an easier way of streaming to the pad,
Any help would be greatly appreciated.
Oh and Happy new year to one and All.
Best Regards
Dave S. :roll:
Best Regards
Dave S. :roll:
- JonavinAspirantIf you have your main volume shred you can use any text edit that supports unix text (LF only). I usualy use UltraEdit, but there's a free (for personal use) editor called Edit Pad Lite if you're using a Windows machine.
- BitzerjGuideI updated the file (Config file)
I see the server...see all the folders....see all the files. I was prompted for the password. Unfortunately the all still say Invalid, AVI files and MPEG files.
Ugh.... - chirpaLuminaryPeople with invalid files are probably NVX systems? The add-on only has 64-bit ffmpeg in it, but the NVX is 32-bit, so it can't run there.
- BitzerjGuideNope...Invalid on an Ultra, not NVX.
- PatrikJAspirantI use NVX, and get Invalid... ...is it impossible to use NVX with AirVideo?
- mdgm-ntgrNETGEAR Employee Retired
Bitzerj wrote: Nope...Invalid on an Ultra
What version of RAIDiator is installed on your ReadyNAS? Could you try rebooting and then attempting to install the add-on again?PatrikJ wrote: I use NVX, and get Invalid... ...is it impossible to use NVX with AirVideo?
May be possible, but no addon to do it at this time. Hopefully super-poussin releases an addon that'll run on the NVX. - BitzerjGuideIt's the latest version (Production, not Beta). I rebooted twice and still invalid.
- mdgm-ntgrNETGEAR Employee RetiredTry a firmware (OS) re-install, then attempt to install the addon again.
See http://home.bott.ca/webserver/?p=252 - BitzerjGuideHi - I tried to reinstall the OS and the application. Still getting the invalid files.
- joeyyoungAspirantHas anyone resolved this? I have the NVX and getting an 'invalid' error for all of my video. Tried all kinds of types and conversions types but everything is showing as invalid. I am running latest RAIDiator 4.2.15.
Also tried re-installing the Add-On, and rebooting and OS RAIDiator Re-install.
I did find that MP4's do play. *BUT* AVI, MKV, etc. will NOT!
I think this is broke...or maybe we need to update or configure something.
