Bob245
Apr 30, 2019Guide
How safe can be a iSCSI LUN with CHAP security
Hi everyone, I have a RNDP4000 NAS unit with 4 WD 3 TB disks each and firmware 4.2.31 version. Before I upgrade to the OS6.x version (because I would like to have the encryption feature) I wanted to...
Apr 30, 2019Guru - Experienced User
Although I don't use the iSCSI LUN feature myself, I believe that that CHAP authentication might not be enough to protect against theft. It does authenticate the initiator (and optionally the target). But since the thief has direct access to the LUN container, he might still be able to extract your data without using an initiator.
Since the LUN is block storage and is formatted by the client, you should be able to encrypt the LUN itself. That would block direct data extraction (and any initiator would also need to know the encryption key). You could combine that with CHAP.
IMO this feature has limited value, because you need to keep a thumb drive with the encryption key near or in the NAS. The thief likely will steal the key also, and could figure out what it is for. At least you should assume that he will.
Operationally, you need to insert that key whenever you boot the NAS. That includes cases where the NAS is rebooted when you install the firmware and when power is restored after a power loss.
Sandshark
May 01, 2019Sensei
I put critical personal files in a VeraCrypt container on the NAS. I run Veracrypt on the PC, not the NAS. Also, unless you are content with incredibly sluggish writes, put VeraCrypt containers in a volume with strict sync disabled.
A BitLocker encrypted VHD or VHDX virtual drive can also be used if you have Windows Pro. Strict sync doesn't bother it.
