Bob245
Apr 30, 2019Guide
How safe can be a iSCSI LUN with CHAP security
Hi everyone, I have a RNDP4000 NAS unit with 4 WD 3 TB disks each and firmware 4.2.31 version. Before I upgrade to the OS6.x version (because I would like to have the encryption feature) I wanted to...
Sandshark
May 01, 2019Sensei
I put critical personal files in a VeraCrypt container on the NAS. I run Veracrypt on the PC, not the NAS. Also, unless you are content with incredibly sluggish writes, put VeraCrypt containers in a volume with strict sync disabled.
A BitLocker encrypted VHD or VHDX virtual drive can also be used if you have Windows Pro. Strict sync doesn't bother it.
