ScottChapman
Jan 26, 2014Apprentice
how to configure iStat on OS6?
I got iSTat installed and running. But launch button is not active. It does day what port to use, and what the default password, question is, what is the URL? I tried http://<NAS>:5109 but get a...
doylmi
Feb 09, 2014Guide
doylmi wrote: I'll make sure this is clearer in the next iteration. Will probably prompt for the passcode iStat is detected, but the passcode is missing.
This has been implemented.
ReadyAS
Nov 08, 2015Guide
I will describe my case I had on RNDP4000 with OS6:
The stat daemon did not started, so I tried to run it manualy:
root@nas:/apps/istat/bin# ./istatd
and I saw the message:
"Could not read configuration from /usr/local/etc/istat.conf: No such file or directory
root@nas:/apps/istat/bin# more istatd"
So I copied istat.conf:
root@nas:/apps/istat/bin# cp -p /etc/istat.conf /usr/local/etc/
Since this time there was not problem tu run the stat daemon from UI using ON/OFF switch, but still the main RUN button is inactive.
Iteresting that:
"root@nas:/apps/istat/bin# ps -ef|grep istat
admin 18717 1 0 18:45 ? 00:00:00 /apps/istat/bin/istatd -d -c /etc/istat.conf"
I mean "/etc/istat.conf" is as a parameter and "/usr/local/etc/istat.conf" is used in reality? Is the second path hardcoded?
